Old 09-14-2019, 08:11 AM   #1
littlemanjoe
Liked 75 Times in 28 Posts
Default 440 6 pack
Putting together a stocker bottom end and I have 3 blocks to choose from.
The best block checks out with a minimum of .171 cylinder wall thickness. Before machine work is done.
My pistons are .060 over.
The question I have is, would you fill the block or sleeve all eight cylinders?
I've had someone tell me do not fill the blocks you will lose ring seal.
littlemanjoe is offline   Reply With Quote
