02-29-2008, 10:54 PM | #1 |
Liked 56 Times in 27 Posts
Re: Question for a tranny guy
Solid tranny and motor mounts are hard on bellhousings, driveshafts out of balance,you should have a torque strap, use only stock type mounts(rubber)...You convertor is too tight for that combo, I also haven't ever heard of a GP weighing 3,200 lbs...Make sure everything is lined up and nothing else is cracked....Also, check the rearend, you maybe surprised..Good - Luck
Dave...1033/stock(350) Pontiac
Dave Ribeiro 1033 STK |
