Liked 26 Times in 10 Posts
Does Anyone Have PRO/CONS about a specific electric water pump MFG for A SB MOPAR - thank's in advance Bob
Liked 888 Times in 239 Posts
Meziere is the best , hands down.
Liked 805 Times in 341 Posts
Tom is correct. Probably the best customer service in racing.
My son has a water pump he uses some on the street and Hot Rod's Drag Week on his SBM. After it about fifteen years of use he had a problem with it. He returned it for repair and it was fixed and shipped the same day they got it, all for a reasonable price. I have one I have used for years on my SBM race car with no issues. Not a water pump but I had them make me a custom flex plate. It was less trouble than they anticipated and with the flex plate was a partial refund check. Who does that! As you can tell I am a big Meziere fan Bill Lamb |
We have been going back to stock pump with belt drive on most
of our cars. It draws much less juice than separate fan and pump (especially the fan)!
Liked 11 Times in 8 Posts
I have had zero problems with my Mezeire on my 340. I have friends that had problems with the CSR and Moroso pumps. The Moroso motor and factory water pump on the AMX also works fine, but I was told the Mezeire is lighter . The electric fan is the highest amp draw of anything on the AMX, especially when it starts.
Liked 22 Times in 14 Posts
#8 | |
and can use stock shroud and it draws only a moderate amount of juice. With aftermarket pump I have to use an electric fan mounted on the radiator. That fan (no matter the brand for me) draws enough juice that I only run it with engine running (I run real working alternators) OR connected to a battery charger while back in the pits. Hope this helps.....I am old
