Old 07-15-2019, 12:47 PM   #1
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Caltrac split mono
Mine settled over time (roughly 12 years) so I did replace the back half with a little more arch than the stock spec for my car.
Never saw a difference on the timeslip; just the outer tire to quarterpanel clearance.
S/ST 51
S/C 53
Old 07-27-2019, 11:00 AM   #2
GTX JOHN
We have seen only very minor ride height changes over 10 plus years
but never any 60 ft. change. My Demon probably has 1000 passes
on it and never changed the springs. John Calvert makes well engineered
products and has exceptional integrity!
John Irving
741 Stock
741 Super Stock
Old 07-27-2019, 12:09 PM   #3
spike1
Liked 53 Times in 16 Posts
If you haven't yet, and you have an automatic, you might want to think about looking at your converter. Had the same problem your describing and after many $$ and a couple of months it turned out to be the converter although it stalled up the same rpm as it did new. Never had any problems with my Caltracts in 10 years of use.
spike1 is offline   Reply With Quote
