Liked 12 Times in 6 Posts
Anyone ever switch between the Super F and the Max Duty Super F and see a difference in stall rpm or % slippage. Looking to tighten things up a bit on the converter.
Liked 706 Times in 283 Posts
I would also be interested making converter a little tighter. I think trans fluid comes in different viscosity and seeing if anyone has any experience in this. Thanks Jeff
Liked 358 Times in 83 Posts
Obviously, any info you gather here (from racers) will be helpful, but I would call ATI and ask them what they've heard from customer/users, and based on that, what they would expect you to see.
Liked 27 Times in 19 Posts
Try some Mobil 404 hydraulic oil.
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
It will tighten up the converter but not a set amount. Every combination will be a little different.
Marty Rinehart Jr 1125 SS STK SG SC SST |
Thanks Marty that is exactly what I was looking for.
The kinematic viscosity of the Max Duty is similar to heavier hydraulic fluids such as John Deere Hy-Gard and Allison Transynd. Most regular trans fluids regardless of brand have similar kinematic viscosity. I imagine it depends on weight, rpm, and torque on what the converter will see. |
#7 | |
Liked 974 Times in 310 Posts
Liked 535 Times in 110 Posts
Torco also offers low and high viscosity ATF as well.
Jim Kaekel 3836 STK |
Sponsor
Liked 59 Times in 12 Posts
If you do plan on trying the heavier oils, make sure you use a screen type filter, not fabric type
