Old 06-15-2019, 02:57 PM   #1
Painter
Liked 162 Times in 45 Posts
Default Re: Turbo 200
I will have to disagree on this. If you run the vent hose forward and upward into a small vented container then what fluid is in the tube has a ban even to drain back into the trans! Jazz makes a small plastic one pint container with a drain and vent filter that doesn’t weigh much or take up much space on the firewall. Running the vent hose back is inviting not only a mess on the underside of the car but disaster if the trans is overfilled the fluid gets on the tires.
Painter is offline   Reply With Quote
