Liked 230 Times in 94 Posts
Hope this might help. Years ago at the Gators I was told by the rep. for MSD to change the coil wire from time to time as the conductor will break down. This was discovered when pro stockers were having ignition problems. John Kissel K242
Liked 312 Times in 175 Posts
In other words: the internal wire is going bad. Should you not see this with an ohmmeter?
Liked 73 Times in 36 Posts
The typical spark plug wire used today in some of the racecars should be a magnetic core with radially wound monel wire wrap around the core. Unfortunately quality is all over the map. Many wire sets do not follow the original French patent of using a magnetic core....problems abound when decreasing manufacturing costs. The coil wire sees more energy per time than do the individual plug wires and over time the wire condition can break down.
![]() ![]() An easy way to keep track of the secondary wire condition is to log (record) the resistance (Ohms) when the set is new and periodically re-test it and compare to the base log data. Another easy way is to run the engine in total darkness and look at the corona discharge at each end of each of the wires. This glowing corona discharge will grow over time and is a decent indicator of when one should consider changing wire sets. ![]() Regards to All that like this kind of stuff, HB2 Dissident ![]() |
Liked 7 Times in 5 Posts
just had this same issue car wouldn't run over 5 grand and was load sensitive ignition box was the problem also 7al2 went to a grid and problem was gone.
