We run N and also have a roll bar and 5 pt harness.
You do not need passenger belt UNLESS you are riding with a stuffed animal (Seen that before) or an inflatable sex doll (Had that put in my Demon before)!
Liked 129 Times in 59 Posts
If it makes any sense, yes, OE seat belts are OK from N on down, BUT if you install an SFI-rated harness you must replace it every two years. First thing I did was replace the almost 45-year-old driver's belts in the 'wagon, figuring that my peace-of-mind (and safety!) was worth $35 a year. I don't run a roll-bar yet, so i don't use the shoulder harness. I also just left the other OE belts alone.
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 249 Times in 48 Posts
In the past old belts were ok if they were not required. Has that changed?
Liked 460 Times in 91 Posts
I run expired 3in belt in my car all the time with no problems and nobody complaining
Bob Bender 144 O/SA 2010-2012 National Record Holder |
