#31 |
Liked 7 Times in 5 Posts
unless its changed this year due to some factoring the 1970 360 4bl is a really good Super stock combination currently with only a 260hp rating i know a couple of people who are building this combo.
#32 | |
Liked 4,578 Times in 1,733 Posts
74 -77 Hornet ..Looks the same to me. Nobody knows. Nobody cares. Several guys here are very familiar with this combo.You already got the basic blueprint. Go..
We are lucky we don't get as much Government as we pay for..... Will Rogers |
#33 | |
Liked 279 Times in 110 Posts
1. Big Bore 2. Good amount of lift 3. Lots of head flow |
#34 | |
Liked 703 Times in 206 Posts
I've got quite a bit of experience with all the AMC combos,but the '77 258 is a very affordable build that ran run well without high dollar converters or transmissions or suspensions. The BBD 2bbl carb is very workable , the cam and blueprint specs are very favorable. A smart builder can run more than a couple tenth's under the index with cast Badger pistons , $100 rings ,stock rods and without doing anything to the head but the valvejob. The 232 1 bbl combination is a looser dont waste time or money .
#35 |
What do you guys thank about a 79 2 door concord with a 258 2bl and a 904 torqueflight asking because we have the car and alot of the basic pieces to get it going.
#36 |
It's okay ..Makes U/SA , which is still a V8 class. Not enough heads-up around to worry about though. All the previous details still apply.
#37 |
#38 | |
Not fun , nor economical to have to worry about running the index all the time.
#39 | |
Liked 137 Times in 67 Posts
Ideally find something heavy enough to run V. Jim Mantle 6632 V/SA |
#40 |
didn't there used to be a cam lift rule that allowed all cars under x amount of lift to go use x amount of lift.
