Old 04-23-2019, 06:29 PM   #21
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: 1985 mustang GT
What is your budget? There are more 85 GT stockers than traditional SS cars in competition. A stocker 4-5 speed vs a SS 4-5 speed clutchless will have a cost difference. A set of legal SS heads will be no less than 6K and more if you use the replacement aluminum head.
Sean Marconette
84 Mustang
5060 SS/N
Old 04-23-2019, 09:19 PM   #22
tjg4036
Liked 2 Times in 2 Posts
I’m definitely leaning towards ss I have specific questions about the motor what intake manifold are they using stock ford or what aftermarket intake is available are most using a stock carb or Holley aftermarket.
tjg4036 is offline   Reply With Quote
Old 04-25-2019, 01:40 PM   #23
Chris1529
Liked 70 Times in 29 Posts
Definitely not using a stock Ford intake for Super Stock.
A lot of super stock guys use custom made sheet metal intakes, but there are several single plane intakes available as well.
Any carb is going to have to be massaged by someone This is just my opinion, but if you start with a new quick fuel or a Holley 600, I think you would end up about the same place performance wise.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 04-25-2019, 03:41 PM   #24
tjg4036
Looking at rule book under intake manifold it says any manifold of same configuration as original. You can use a sheet metal intake?? Damn
Old 04-25-2019, 06:16 PM   #25
What that means is the carb has to be in the same relative place. Anything else goes, as long as it will fit under the hood
Old 04-25-2019, 11:20 PM   #26
tjg4036
Ok so original carb and heads and short block anything goes for cam valve train and intake manifold
Old 04-26-2019, 08:44 PM   #27
Chris1529
When you say original short block, what exactly are you thinking of? Just the block or the internals?
Chris Bowman
1984 Mustang GT350
Old 04-27-2019, 09:38 AM   #28
tjg4036
I just didn’t realize that ss was allowed so many mods like sheet metal intake manifolds. But the short block is relatively stock
Old 04-27-2019, 05:13 PM   #29
Hacksaw
Liked 312 Times in 175 Posts
About the only thing "stock" in a Super Stock short block is the location of the bolt holes.
Old 04-27-2019, 06:42 PM   #30
tjg4036
I’m seeing that. Looks like stock it is for me.
