Liked 373 Times in 131 Posts
Quick Fuel makes a legal carb for the 83-85 4bbl H.O.
Liked 2 Times in 2 Posts
Thank you. Stock or super stock for this 1985 mustang which is the better way to go as far as competition cost performance and expense.
Liked 275 Times in 76 Posts
What is your budget? There are more 85 GT stockers than traditional SS cars in competition. A stocker 4-5 speed vs a SS 4-5 speed clutchless will have a cost difference. A set of legal SS heads will be no less than 6K and more if you use the replacement aluminum head.
I’m definitely leaning towards ss I have specific questions about the motor what intake manifold are they using stock ford or what aftermarket intake is available are most using a stock carb or Holley aftermarket.
Liked 70 Times in 29 Posts
Definitely not using a stock Ford intake for Super Stock.
A lot of super stock guys use custom made sheet metal intakes, but there are several single plane intakes available as well. Any carb is going to have to be massaged by someone This is just my opinion, but if you start with a new quick fuel or a Holley 600, I think you would end up about the same place performance wise.
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Looking at rule book under intake manifold it says any manifold of same configuration as original. You can use a sheet metal intake?? Damn
What that means is the carb has to be in the same relative place. Anything else goes, as long as it will fit under the hood
