Liked 88 Times in 43 Posts
Please give us more information Dan.
You have access to a solid roller out of a 350/255 engine? Are you trying to run said camshaft in Stock Eliminator? Like Ed said, if it has stock diameter journals, not big block, not metric, it should go in the block and rotate. I would expect it to have much more lift and duration than a stock(er) cam. What will you do for valve springs? Lifters? Rocker Arms? What about piston to valve clearance? Will it fit? Maybe. Will it work? You have to cover the bases. |
