Liked 62 Times in 23 Posts
What material is best to block exhaust heat passages on iron heads, SBC?Also, what is best procedure to accomplish from intake side, thanks, Tony.
Liked 883 Times in 237 Posts
I haven't done any in a while ,but I used to use old cast pistons ,busted them up and melted in a iron pot on a turkey fryer burner . skim off the dross before pouring.
Make sure you have enough to do the fill in one pour . It helps to preheat the head casting as well to prevent the pour from shocking the casting and keeps the aluminum from chilling before the fill is complete. I used furnace cement and chimney packing to dam the crossover in the port side and filled from the manifold side . Be safe , take your time.
thanks Tom, Tony
