Old 03-06-2019, 10:29 AM   #11
SDT1DYI
Liked 456 Times in 148 Posts
Default Re: Replacement heads on Stocker
It is curious how NHRA tech dept approves a replacement cylinder head when the runner volumes are considerable larger than their own stated specification. Its been said replacement heads are worth 15-20 HP on a SBC combination. The replacement heads with the HP penalty, seem to produce the same ETs.
Steve Teeter. STK. 6380
SDT1DYI is offline   Reply With Quote
Old 03-06-2019, 11:03 AM   #12
Alan Nyhus
Liked 799 Times in 236 Posts
Originally Posted by SDT1DYI View Post
It is curious how NHRA tech dept approves a replacement cylinder head when the runner volumes are considerable larger than their own stated specification. Steve Teeter. STK. 6380
A good example is the Edelbrock NHRA accepted head for small block Chevy Stockers.
- OEM head: 165 cc intake/65 cc exhaust
- NHRA specs on Edelbrock heads (5 hp penalty) : 172 cc intake/65 cc exhaust
- Edelbrock's specs on these heads: 185 cc intake/65 cc exhaust
When I asked an NHRA Technical official about this, I was told (paraphrasing) that if anyone showed up in Stock with the accepted Edelbrock heads, they would be illegal if they had the 185 cc intake ports. And if the intake ports measured 172 cc, they wouldn't pass because they would have to have been illegally modified (welding) to get down to 172 cc.
"That'll never work....."
Old 03-06-2019, 04:50 PM   #13
Coleydog
Liked 53 Times in 38 Posts
I think I heard that phrase before, we'll pass it to see what's in it.
Mike
Old 03-06-2019, 07:22 PM   #14
bubski
Liked 165 Times in 60 Posts
So !! a set of closed chamber iron heads is more expensive than a new set of aluminum heads ?? Whats next ?? the cam is hard to grind with the stock lift ??
bubski is offline   Reply With Quote
Old 03-07-2019, 03:13 AM   #15
RULER
Liked 58 Times in 18 Posts
Exclamation Re: Replacement heads on Stocker
This replacement head deal is way out of hand, there are plenty of good stock casting for SBC and oval port and square port BBC, you just have to get your wallet out and there really not that expensive when your building a competitive stock or super stock Engine, And no you can't buy them from jegs or summit.
RULER is offline   Reply With Quote
Old 03-07-2019, 07:30 AM   #16
Liked 10,889 Times in 2,255 Posts
If anyone needs some 906 cores I have 40 to 50 heads.
Old 03-07-2019, 10:45 AM   #17
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Yep
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 03-07-2019, 02:26 PM   #18
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Hi All,
The reason that most of the replacement heads are only legal in Super Stock is that they have to be modified by filling in the runners to the correct cc's.
You can't weld or use epoxy in the runners of a Stock head.
Combustion chamber volume can also be adjusted in SS and not Stock.
The replacement head just supplies a blank sheet of paper to start with and can be made legal by machining.
Whatever you use it must conform to the NHRA Blueprint Specs including valve size.
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 03-07-2019, 02:28 PM   #19
GTX JOHN
Liked 2,490 Times in 700 Posts
Smile Re: Replacement heads on Stocker
Larry:
I can match your fifty 906's and raise you 20 more.
About 200 Mopar heads on shelves in my shop.....Some
for 40 years or more!
John Irving
741 Stock
741 Super Stock
Old 03-09-2019, 12:36 PM   #20
Liked 1,912 Times in 429 Posts
That's hilarious. How many heads and engines do you build? And just how good are you at welding cast iron heads for Super Stock?
