Liked 238 Times in 113 Posts
Is this the type of fuel system that doesn't have a fuel return up in the engine compartment ? I think the factory had the return and possibly the regulator back by the fuel tank . You may want to re-engineer that so it is similar to the old LT1 , which regulated fuel pressure on the return side of the fuel rail . Once you do that , the fuel sample valve will be easy to plumb in . That will then be similar to how I plumbed up my Oldsmobile Quad 4 .
I have my fuel sample valve tapped into the fuel return line on my LT1. I also have a button near it, to push to run the pump for filling the fuel sample cup. Just a universal starter button. Both under the hood. Quick, simple fuel sample.
Ed Wright 4156 SS/JA |
Liked 5,077 Times in 1,935 Posts
Mike, You should have a pressure test port there somewhere.
This is how I did it on the Monte. I removed the Schrader valve and adapted an AN type fitting that changed everything over to 1/8th pipe. Then the sample valve on a tee and then onto a braided hose to the cowl mounted pressure guage, which you're going to need anyway. Yes, also an under the hood mounted fuel pressure relay feed switch. ![]() ![]()
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 02-21-2019 at 11:35 PM. |
Liked 39 Times in 8 Posts
Thanks all for the replies.
We wound up doing what Mark suggested. And now I know for the next one. LOL
Mike Meier "World's most expensive DF/S" 2007 Chevy Cobalt....because suffering through owning an AMC Stocker wasn't enough |
Liked 10,655 Times in 2,211 Posts
I use a stainless ball valve off of the regulator. I have used same ball valve since the 1990's
