Old 02-13-2019, 10:06 AM   #14
Steve Stasko
Liked 274 Times in 143 Posts
Default Re: Evans Coolant
Originally Posted by SG RACER View Post
Car has a Afco scirocco radiator/fan/shroud and a Meziere 55 gpm pump with 16 an hoses top and bottom. Had a 12 an hose from top of intake to top radiator and switched to 16 an and it did help with cooling the motor down a little faster but still can’t cool down very quick.
The larger AN helped because the pump was able to push more coolant through the radiator. The more coolant you can push through the radiator, the faster it will cool. At the same time though, you're trying to push 55 gallons of fluid per minute through a 1" (16 AN) hole. You really need to open up the inlet/outlet to get more coolant through the system. You could put a stock water pump on, and see no change in temperature, with the restriction being caused by the 16 AN inlet/outlet...
I understand you may be space confined with your application, but I would see if I can get something larger than a 2'x1' Scirocco rad. I honestly didn't even know those things were still being used outside of dragsters and altereds.
