Old 01-20-2019, 06:22 PM   #81
Default Re: Fly Weights
I have to wonder if NHRA would let you use the alcohol injection? If you look at the Mecum pictures, you can see the alcohol tank on the drivers side of the radiator.
Probably wouldn't need it with the $20 approved fuel ;-)
The turbo cars had a side draft Rochester. Other models had a 4GC.
The suspension is similar to a Chevelle, but the coils are on the trailing arms, like a Fox body.
I doubt anything modern would bolt it to replace the Jet-a-Way (Slim Jim)
Probably could use a later Land Rover block that might have the B.O.P. pattern.
Old 01-20-2019, 07:10 PM   #82
Billy Nees
You're (of course) right about the carb. Same as turbo Corvair, wasn't it?
As far as the alcohol injection, didn't they inject it into the turbo to cool it?!?
Looking at the pics, I guess they inject it into the carb..
Billy Nees 1188 STK, SS
Old 01-20-2019, 07:39 PM   #83
Actually, the Corvair used a Carter, but similar style.
Rather than lowering the compression, Olds decided to inject the fluid to cool the combustion..
I'd suggest using an MSD Boost Master timing retard control with this one ;-)
Old 01-20-2019, 08:18 PM   #84
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
https://forums.aaca.org/topic/108020...draft-rochest/. To complicated for 1963. I do recall at least one that came in the station I worked at. Plagued with problems. Engine and trans. The Slim Jim was poor in everything GM put it in.
Rich Biebel
S/C 1479
Stock 147R
Old 01-21-2019, 12:14 PM   #85
Billy Nees
Well, seeing as it's 3* outside and the wind is blowing like a banshee AND boredom is setting in,
how about a 63 Chevy II 4cyl 153/90/90 for W/S or W/SA at 2330?
Same basic engine as my 230s minus 2 cylinders.
I guess the problem would be finding one but it would be fun with a stick and probably pretty quick with a metric!
Old 01-21-2019, 12:17 PM   #86
Mike Jones
Liked 684 Times in 289 Posts
Iron Duke?
A nice life for a metric, behind one of those...
Mike A114
Old 01-21-2019, 12:23 PM   #87
Billy Nees
Iron Duke?
Mike A114
No, kinda like the "Iron Dukes" grandfather.
Old 01-21-2019, 12:57 PM   #88
Mike Jones
ok,
Iron Duke late 1960`s? I recall a 68 or 69 Nova w/4 banger, and a guy called it an Iron Duke.
Old 01-21-2019, 01:01 PM   #89
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Weren't those used in marine applications a lot?
Dwight Southerland is online now   Reply With Quote
Old 01-21-2019, 01:11 PM   #90
Mike Jones
I think they were...
