Old 01-07-2019, 05:04 PM   #1
vic guilmino
Liked 56 Times in 21 Posts
Default make small hot tank
my wife was thrown out a heated pan. so i will make small hot tank, but what chemical sould i use in it
Vic Guilmino 1129 STK
Old 01-07-2019, 05:27 PM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: make small hot tank
Moonshine !
Old 01-07-2019, 07:12 PM   #3
Coleydog
Liked 53 Times in 38 Posts
RedDevil Lye, drain opener. Very caustic so be careful, pore in slowly, it makes its own heat. Once the heat is gone, put a lid on it to seal for next use. Works better if heated. USE RUBBER GLOVES. Will clean and remove anything, rust, paint, grease. There are many different chemicals to use, depending on what you want done. I have large molasses, muriatic acid and electric tanks. Next is the stainless steel tank for the lye. Been Keeping an eye out at the recycle yard. Unbelievable what commercial restaurants throw away, I've found many large stainless buckets, pans for parts washing.
Mike
Old 01-07-2019, 10:59 PM   #4
House of Darts
Liked 20 Times in 15 Posts
Heat makes chemistry work harder. Heated tanks are great. Buy your lye from a supplier as opposed to using drain cleaner. Not needing to be listed, don't know why, some lye based drain cleaners use heavy metals for a bigger kick, and are short lived. With a temp of 90+ try the Sam's club HD degreaser. Cheap and concentrated. If you plan on cleaning aluminum, lye and certain degreasers are a no-no.
House of Darts is offline   Reply With Quote
Old 01-08-2019, 09:47 AM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Coleydog got it with the Red Devil lye ….cheap and effective.
I've been using it for years since machine shops have been getting rid of their old caustic hot tanks.
I use a large heavy duty 23 gallon storage tub with a bung installed on the side with an old oil pan heater element I had laying around in it .
I try to keep the temp around 175-80 and I have a tube thru the cover that I can hook up to the air hose to aerate the mix and keep it cleaning.
What ever you use for a container, if it's plastic make sure it will crush and deform , not crack .
Old 01-09-2019, 06:39 PM   #6
outlaw
outlaw's Avatar
Liked 132 Times in 52 Posts
Lye to water ratio?
outlaw is offline   Reply With Quote
