Old 12-09-2018, 12:04 PM   #1
Eman
Liked 133 Times in 76 Posts
Default Re: Master cylinder question
Originally Posted by GallopinGhost View Post
I just bought a new strange MC. Their recommendation is with 4 wheel disks, use a 1.125 bore and with 2 wheel disk, 2 wheel drum to use a 1.032 bore. I can say, without even bleeding the lines the pedal feels good, better than the mopar aluminum one I had on
What differences are there between the Strange MC and the Mopar aluminum one? Isn't the Strange basically an aluminum Mopar MC?
Old 12-09-2018, 02:04 PM   #2
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Not sure what the differences are. the mopar one might have had an issue, Although one thing I did different going from one to the other is that I now have the rear brakes plumbed to the rear port on the MC. I read that the rear port provides more fluid flow, and I'm trying to make sure I have good holding power on the rear when staging. we'll see.
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 12-09-2018, 02:17 PM   #3
Eman
Unless it's a stepped bore MC, 2 different size bores in one, the only difference in ports is the capacity of the reservoir. Disc brakes are self adjusting by allowing fluid to take up the space as the pad wears so the reservoir is larger.
If you want more holding power in the rear increase the size of the wheel cyls or calipers.
Old 12-09-2018, 02:27 PM   #4
GallopinGhost
I've got strange discs in front and back with their recommended MC. I'll wait and see how that works.
Brian Carpenter
Stock 1358
