Old 12-08-2018, 04:59 PM   #1
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: math class needed on valve springs
If you can find a comparable spring on the PAC Racing site, this link to their spring rate calculator might help.
https://www.racingsprings.com/index..../?sku=PAC-1224
Edit: Change the part number to your match.
Dale Shearon
68 Mustang 6394
Old 12-08-2018, 06:08 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
The basic formula is F=kX . F is the force , k is the rate , X is the difference in spring height from the length of the spring when it is not loaded .
Old 12-09-2018, 11:47 AM   #3
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
This is correct.
To add to above, the spring rate is stated as the force generated per unit of compression. Ex: 1,000 Lbf/Inch, 1,700 N/cm etc.
Also, its spring FORCE, not pressure. Spring pressure is a common misnomer racers seem to always use, and it just wont die. Its entirely wrong. Its not a pressure, Its a force.
