Does anyone have any comments on the ADP throttle stop carb? Thanks, Doug Humes s/g 3880
Liked 431 Times in 224 Posts
The Max Speed carb? I've seen many racers try them, then go back to a traditional under-carb stop.
The APD house car that won S/C at the US Nationals uses a separate under-carb butterfly stop.
S/ST 51 S/C 53 |
Liked 4 Times in 4 Posts
I’ve had 2 and still have one on my current car. I love em. If you set it up like that tell you I don’t see how you can beat it
Liked 100 Times in 51 Posts
I love my separate APD carb and throttle stop............
Dan
Dan Foley SC 4698 |
Liked 759 Times in 379 Posts
What stop was it. Was it a APD under carb stop. I have a 1stop that I’ve had since 2001 and been on shelf for awhile. Thinking of changing scoop over winter so I can use a under carb setup again. I know Stinnett has one now and was thinking APD also had one. The 1stop I have is a electric version.
x2. I have two of them. I had one electric and one air, but had the air stop converted to electric.
I know #1 Stop does have a new "hi-velocity" unit that some guys have had success with. If I were you, I'd use what is on your shelf.
S/ST 51 S/C 53 |
