A friend of mine here in gonzales la been running that !!! Keith hunter w powertrain specialist !!!! Works gd !!! Js
Liked 425 Times in 51 Posts
I long time friend and serious bracket racer who owns a trans shop told me it does run a little more consistAnt but if you get into close back to back runs it doesn't stay as cool as regular trans fluid
Liked 372 Times in 130 Posts
I run the John Deere Hygard fluid in mine ( $ 17 a gallon)
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
Liked 706 Times in 283 Posts
I understood in using it to tighten a N/A converter that gets nitrous applied to it. With nitrous a converter becomes way to loose and with the hydraulic oil it will bring it back 3-400 rpm's
Liked 70 Times in 31 Posts
We ran it in the Nova and it worked fine. Supposedly more consistent. I don't have data to back that up. I don't like the smell of it or the feel so probably wouldn't use it again. I have it in my Chevelle bracket car but will most likely put ATF back in it when I change it.
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
I run Amsoil screw compressor oil in our super comp cars as it seems to be more consistent while on the stop. Now that we are jumping into stock as well I have not decided if we will run it in the car.
Brian
Wanted... something for nothing, you pay shipping! |
