Old 09-08-2018, 11:53 AM   #29
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: 302 Chevrolet Engine Build
Yac-
Leaving “on the mat” back then is not the same level of strain as the sustained 8000+ rpm runs of today’s cars. Secondly, we broke a bunch of rods back then, too! And if you break a rod in an engine today, it’s way too expensive to consider taking a chance.
There were only three small journal rods - early 265, ‘57-‘62 265 & 283, and the ‘63-‘67 283 & 327. There ware no special high performance forgings. The solid lifter ‘65-‘67 engines sometimes got “green” rods which meant they were magnafluxed before they were machined. All these rods are 50+ years old today. Do you want to trust them for a $10K engine?
Head casting numbers changed due to engineering changes that had nothing to do with port design. 462 changed the combustion chambers, 291 made allowance for closed crankshaft ventilation with open slots between the push rods, and 186 had the provisions for bolt holes in the end.
Just a bit of history.
