Liked 239 Times in 114 Posts
Apparently you have some sort of data acquisition system , assuming you are measuring A/F ratio with a wide band O2 sensor . When on the 2 step , what is the A/F ratio ? Once you release the 2 step , what is the A/F ratio ? Is the A/F ratio consistent at 11.5 through out 1st gear , then goes to 12.5-13.0 after the shift to second ?
Liked 13 Times in 4 Posts
yes we have a racepack. after releasing the 2stepp the afr goes from 10.5 to 12 att the first to second shift after that it varies between 12.5 to 13.5.
What is hard to understand , is usually when your on the two step the O2 sensor is faked out , and will read very lean . This is because the two step interrupts the ignition which means some cylinders don't fire and the air passes right through the engine , and the O2 sensor reads that as excess O2 and therefore lean . Yours is reading rich , which is opposite from what I would expect . You may want to make a run without running the two step and compare the results .
Liked 312 Times in 175 Posts
I firmly agree you have too much main jet. I think you should change the primary jets to # 68, then evaluate.
#5 | |
Liked 706 Times in 283 Posts
#6 | |
In a production car , when the engine misfires the O2 sensor reads lean , and then starts to add more fuel to correct . Most production calibrations will only allow so much correction , and once it reaches that limit , it sets a code . A misfire is similar to what a two step does only more controlled . I am surprised your engine reads rich when on the two step . Hopefully a few more folks will chime in with their experiences . As far as running as big a jet with no rods , I agree , too big , but remember that this particular carb has the POE system , which adds even more fuel into the primaries at WOT . He might have to put a very small primary jet , or reinstall the power piston and primary rods . |
#7 | |
Liked 280 Times in 139 Posts
when on the 2 step afr is 18-19 but afterreleasing the 2 step afr goes from 10.5-12 just before shifting to second gear. poe system blockt. best 60 foot 1.39 best et 10.69 in e/sa should change to 69 pri jet for the next race and but a gopro camera under the hood over the carburator.
the track were we ran 10.69 is 682 ft over sea level and we had 1700 ft of air.
