06-20-2018, 02:01 PM | #1 |
Liked 49 Times in 34 Posts
K-frames on Mopar
Has anyone welded up the seams on the k-frame ( just spot welds now)? Do you think it's necessary?
Mike |
06-20-2018, 05:17 PM | #2 |
Liked 62 Times in 17 Posts
Re: K-frames on Mopar
Weld reinforcement around the LCA shaft boss for sure. Steering box mount needs some help too.
06-20-2018, 09:40 PM | #3 |
Liked 2,149 Times in 784 Posts
See www.firmfeel.com
06-20-2018, 11:18 PM | #4 |
Liked 1,887 Times in 580 Posts
Never had a problem with a stock one EXCEPT in early 70's when I acid dipped them (Bad Idea)
06-21-2018, 05:59 AM | #5 |
Liked 21 Times in 13 Posts
Mike, if you put a notch in it for oil pan removal, as per rule book, make sure to off-set it 2" to the right.
Brian Carpenter Stock 1358 |
06-21-2018, 06:04 AM | #6 |
Liked 135 Times in 49 Posts
It certainly can't hurt. In addition to frame connectors and roll bars/cages, I've heard of cases where people have also welded the body & frame seams on Mopars, all in an effort to minimize any bit of potential flex in the uni-body chassis.
LOCOMOTION Racing |
06-21-2018, 08:01 AM | #7 |
Liked 9,550 Times in 1,982 Posts
With all the welding that is needed, it would be necessary to tie the "K" member down to steel plate to keep it from looking like a corn chip after welding. To reduce some stress from welding, peen it with a numatic chipping hammer. Let it cool before removing.
06-21-2018, 09:43 AM | #8 |
Thanks for all the answers, now I have to take the fresh paint off. Wish I'd thought of this before. LOL
06-21-2018, 12:43 PM | #9 |
Liked 227 Times in 106 Posts
While you are at it , weld on some tie down loops .
06-22-2018, 01:41 PM | #10 |
Liked 70 Times in 39 Posts
AND While you're at it. When you brace that steering box mount.....don't you DARE cut it off and move it over for more header clearance.
