05-16-2018, 09:15 PM | #11 |
Liked 68 Times in 22 Posts
Re: Front tire pressure adjustments
I have 28 inch tall tire on it. Car went 1.33 60 ft this past weekend. Just didn’t know what other B/SA cars run for tire pressure. I run radials on rear.
05-16-2018, 10:07 PM | #12 | |
Liked 4,566 Times in 1,730 Posts
We are lucky we don't get as much Government as we pay for..... Will Rogers |
05-16-2018, 10:39 PM | #13 |
Liked 389 Times in 168 Posts
Blocking, or bias slicks should help.
Ed Wright 4156 SS/JA |
05-17-2018, 12:16 AM | #14 |
Blocking? Are you talking about some sort of a blinder? If so , I really don’t know how to do that. I have seen and heard of people doing that. Are they blocking out the top 2 bulbs ? Do you then use the bottom bulb like a pro tree? What kind of device do you use to block out the top 2 bulbs? I also do not use a 2 step. I just lean on the converter. My 2step button is on my brake pedal. I have always been afraid I would hit the button and activate my 2 step at the finish line. Do you set the low side 2 step low enough where your brakes can safely hold the can without pushing it out of the beams. ?
05-17-2018, 12:20 AM | #15 |
Blocking? Are you talking about some sort of a blinder? If so , I really don’t know how to do that. I have seen and heard of people doing that. Are they blocking out the top 2 bulbs ? Do you then use the bottom bulb like a pro tree? What kind of device do you use to block out the top 2 bulbs? I also do not use a 2 step. I just lean on the converter. My 2step button is on my brake pedal. I have always been afraid I would hit the button and activate my 2 step at the finish line. Do you set the low side 2 step low enough where your brakes can safely hold the car without pushing it out of the beams. ?
05-17-2018, 12:42 AM | #16 | |
Now, by your own description, you're swinging across .000 by about 35 thou. So let's say you slow your vehicle reaction down .035. Your - .020 now becomes a +.015 Great. But what happens when you hit what used to be a +.015? It now becomes a + .050. Not going to win too many that way either. My friend, I think you need to work on something other than the car right now. Just my opinion. I don't consider myself to be a bracket racer. I did win a couple of track championships, but I think I'll let the experts take it from here. Later ,we can get back to the technical items.
05-17-2018, 01:14 AM | #17 |
Yes mark you are correct in determining that my slower lights would be less than stellar. I would rather have more ‘50’ lights and less red lights. Most people would rather have a 50 light than a red light. Most people are not as consistent as you on the tree. We all wish we were but we are not, at least I’m not.i I can read between your lines and I will continue to work on my driving as hard as I can. Hopefully I can get my cars reaction time to go along with my ‘human’ reaction time and get a win one day. Thanks mark.
05-17-2018, 02:37 AM | #18 |
Liked 26 Times in 5 Posts
KD,
I would highly recommend using your 2 step. If you can lower the launch rpm that would be a great help to you. Also, I would it would be more consistent leaving at the same RPM each time. The converter can move a little with air changes and trans temps. Hook up a micro switch that will only allow the 2 step to be activated in low gear. I have mine on my shifter. Good luck out there and keep trying, it will come. Ryan |
05-17-2018, 07:21 AM | #19 |
Thanks Ryan. I think you are correct. I’ll check into hooking up that switch.
05-17-2018, 09:08 AM | #20 | |
Liked 471 Times in 114 Posts
Just to complete the logic circle, you do have a brake pressure gauge in the car and know what brake pressure you are staging at correct? Don't have time to look, etc, get a go pro and video the gauge. If your not consistent with that then there you go. Two step, could help, depends on your carb and how it works when floored, you may also want to upgrade to a brake pressure switch, instead of the brake pedal piece. Log books should give you a clue too. Time trials versus competition etc. Change one thing at a time. Eric
Eric Merryfield 1883 STK |
