#11 |
Liked 974 Times in 310 Posts
As Russ says, check with actual spring pressure. You'll have more p to v clearance.
#12 |
Liked 21 Times in 13 Posts
I think for now we'll leave the valve job as is, I'd hate to lose anything there. I really just need to decide how much to deck the head. Once I get the head from the shop, I'll check it with race springs and see where it's at. Then I'll just get a gasket that will give me what is needed. This project is taking forever and I just want it on the track. Next winter I can do some of the trimming of the valve head and maybe re-grind the cam, hopefully that will enable me to then get a thinner gasket and get some of the compression back. thanks all
Brian Carpenter Stock 1358 |
#13 |
Liked 10,779 Times in 2,240 Posts
While you are waiting on next winter find out what is available for gaskets, pistons, rods, and block deck height. In your spare time learn how to juggle. lol
#14 |
Liked 11 Times in 8 Posts
The Steel Shim head gaskets for a small block are very hard to find, the Mr. Gasket head gaskets are .028, about as thin as I have found. Might not be able to get the .021 gaskets you mentioned. I was taught not to sink the valves. So I wouldn't personally do that if there was another solution.
#15 |
Liked 53 Times in 38 Posts
Well Brian looks like we're in the same boat. Someday you and I will get these cars done. Look out world. LOL
I need to get down there a take a look see. Mike |
#16 |
I am confused.......How can you tell piston to valve clearance BEFORE
you CC Heads and know how much they will be milled. It is not unusually to mill BB Mopar heads .060 or more to get the correct specs. Every thousand you mill them bring them closer to piston. How can you measure accurately piston to valve prior to finishing the heads that are actually being used on engine What did I misread on this post?
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 04-21-2018 at 05:19 PM. |
#17 | |
Liked 22 Times in 22 Posts
don,t have one |
#18 |
John,
Maybe I didn't explain very well what I'm doing. The whole purpose of this exercise is to figure out how much to machine the heads. I have a finished block with the crank, 1 rod/piston, cam, head gasket, and a spare assembled head, with valves and rockers, and an adjustable pushrod. I then take P/V measurements. Then measure the valve drop on my spare head, which is the travel of the valve to the head deck. Next I compare the valve drop on my new head at the shop to mine. If the new head had .010" more valve drop, I should have .010" more P/V clearance. The steel shim gaskets are mopar performance and are available from mancini, for $20/set. Felpro 1009 is what I'll probably use though. Not angle milling the heads.
#19 |
I'm enjoying the juggling match now, but then again, I don't have a running engine yet. Lol
