Liked 424 Times in 50 Posts
Well I'm going back to " more fun racing" banging them gears!! I get my new G Force 4 speed Monday I hope to have it all in sync by the SportsNats. Looking forward to rowing down the track!!
Liked 651 Times in 184 Posts
Cool! I'm converting my 69 Camaro 427 also to AA/S .
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA Last edited by TOSTO RACING; 04-01-2018 at 10:59 AM. |
Liked 779 Times in 193 Posts
Really is the fun way to go.
Todd Greene |
Liked 520 Times in 132 Posts
The only way to go!
Great choice on the G Force! You will love it!
Joe Martens AA/Stock 3969 |
Kenny, make sure you check your end play so that your input shaft is not bottoming out against the pilot bearing. The splines are longer on the G Force and could cause a problem. The cure is to just run a spacer between the block and bellhousing. Also, depending on which Jerico you ran, their common length transmission is 2 inches longer than a G Force, although they make a shorter version which would be the same as a G Force. Other than that you should be good to go!
Let me know if you have any other questions.
Thanks joe I'm using the McLeod bell housing it is really nice I heard u had to space the QuickTime bellhousings because they are made too shallow I used a Lakewood w the jerico, I haven't started assembling yet I hope my drive shaft is right. Btw how hard do u have to pull the stick w the G force? I've had some tendinitis in my right arm lately but it is better. Like a friend of mine said "getting old and living for Jesus isn't for wimps!" I'll b 70 this year and I'm thankful I can still get out there and play!
Kenny, call me when you get a chance. 440-897-9769.
