03-26-2018, 01:04 PM | #1 |
Liked 559 Times in 158 Posts
PAC springs valve spring locators?
Having a problem with a new set of springs PAC 1409X being installed on my 882 heads. I will need either locators or a different retainer to get the correct installed height and 200 lb seat pressure.
Problem is I cant find anyone that makes either a spring locator with a .760” inside diameter and 1.25” outside diameter with an .840” valve spring inside diameter. Does anyone make something like this or is there another solution we are missing? Thanks Rich |
03-26-2018, 01:48 PM | #2 |
Liked 167 Times in 77 Posts
Re: PAC springs valve spring locators?
plus or minus machined locks from crane or comp cams can help... if u use plus .050'' locks you have to watch the retainer to underside of rocker. roller rockers there should be sufficient clearance there....what is the required installed height and what r u getting presently?
03-26-2018, 02:01 PM | #3 |
We got 1.90” with the retainer and 140 lbs with no shim. We can shim it up to 180 but not much material left to locate the springs then
03-26-2018, 03:17 PM | #4 |
a retainer providing less installed height and/or -.050'' locks should get you down to 1.800''. leave the bottom alone to help keep the spring located properly.
03-26-2018, 07:18 PM | #5 |
Thanks Class Racers and Jim Marshall and Jim Lewis for getting me squared away!
03-26-2018, 07:51 PM | #6 |
Liked 29 Times in 16 Posts
Rich,
Just want to add that it would be a good idea to get the same brand keepers as your retainers. I have seen a bunch of cases lately where locks from one manufacturer do not properly fit another's retainer etc. And this is not no-name stuff. You would think that any 7 degree lock should fit any 7 degree retainer but it is not the case.
Bill Koustenis |
03-26-2018, 08:24 PM | #7 |
Thanks Bill, yes we are using matched retainers and keepers from the same manufacturer
03-27-2018, 07:36 AM | #8 |
Liked 10,058 Times in 2,087 Posts
Sometimes machining a new part is necessary to get the locator to fit the head. For some of us its not a Chevrolet world.
03-27-2018, 10:17 AM | #9 |
Liked 704 Times in 305 Posts
