Hey Guys, I have a Ford C4 with an expired bellhousing. Does anyone re-certify them or do I have to buy new? I am unsure who the manufacturer is. It's on a '13 CJ.
Liked 336 Times in 183 Posts
Joel's on Joy was the OEM to Ford might give them a call--FED 387
Liked 358 Times in 83 Posts
I think Bill Diehl does that. Send him the bellhousing and $200.
Thanks Guys. Found out that it's a JW bell and I'm getting it sent to them.
Liked 84 Times in 42 Posts
If you are running in a class that doesn't require a certified bell housing but you happen to use one does the certification need to be kept up to date?
Bob Tilton 568 FS/H |
At our track they require all cert’s per NHRA. If you are sub 9.99 why not just do it right and not have to worry anywhere you want to race/run?
Don’t forget about the case too Mike... or maybe you are going to run a blanket?
Ross Gregory 5133 Stock,Super Stock 53 Top Dragster |
Liked 431 Times in 224 Posts
If you don't require a flexplate shield, then you can run with an expired SFI bellhousing.
S/ST 51 S/C 53 |
Hey Ross, found out the case is not SFI so I'l buy a new shield and have the bellhousing re-certified and it should be good to go!
