Old 03-04-2018, 10:49 PM   #8
Liked 5,121 Times in 1,952 Posts
Default Re: Sfi 200 metric case
While there is not an SFI case for the T-200, if you want a stronger case, if you can find one, use the BOP T-200-4 case that was used on GM cars that were powered with the Oldsmobile 350 Diesel engine.
The bellhousing and case is way stronger and even heavier because the additional material in the case.
Joe, Did they make a 3 speed diesel case?
