Liked 204 Times in 54 Posts
How many more ways can Ford screw up a good thing? They made a great block with great materials and bulked it up in the right places but decided to shorten the bores for all the wrong reasons and there's something else that they screwed up.
They put scalloped water jackets on the outside of the deck so now you can't use a production heads on the block. The lip of the water jackets are uncovered with the stock head. That was never a problem with the R302 block. There were round holes drilled on that block. If you needed to you could just plug them. I don't care who from Ford Racing comes on here and spews some reason for this stupid design. They just gave away business to Dart that did their homework and probably looked at heads and asked racers what their blocks should have and should not have. At any rate, has anybody managed to make the Boss Block work with production 302 heads? I would be grateful to learn how since I now have a $2000 block that is worthless for stock and super stock. : |
Liked 92 Times in 36 Posts
#3 | |
I'm just baffled by it. |
Liked 776 Times in 199 Posts
My superstock motor Kuntz did has a Boss block with stock cast iron E7TE heads. Might wanna ask them
Bret Velde 2003 SS/LA. |
Liked 50 Times in 23 Posts
Boss Block, Iron (Explorer) GT40P's, Cometic .027 mlg , no issues
Steve Stickel 1161 Stk 1167 SS |
#7 | |
Since Ford made this great idea you would think they would make some kind of expansion plug for the holes. I may make my own punch and die but Ford should have already done that. |
Liked 223 Times in 73 Posts
Ok just relax i had the same thing happen to me. Filled it up on the dyno poured out i looked like idiot. Had a machine shop put cast iron rod pressed in the block to fill those holes. Cost me $600 i think but all has been good, this is a stocker with e7te heads been this way for years now lots of runs on it. In the catalog there is fine print about this didn't see this till after the fact. Have pictures on an old phone can send you. Will be a couple of weeks till i get home, racing in Arizona right now.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
