Old 02-04-2018, 07:27 PM   #1
J.R. Haddad
Liked 1,453 Times in 306 Posts
Talking How much oil?
How much oil should a Metric 200 with a Turbo Action
deep pan hold. Thanks.
J.R. Haddad is offline   Reply With Quote
Old 02-04-2018, 08:15 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: How much oil?
Why not call Turbo Action?
Ed Wright 4156 SS/JA
Old 02-04-2018, 08:17 PM   #3
J.R. Haddad
Their closed on Sundays. LOL.
Old 02-04-2018, 09:29 PM   #4
jimmyparker
Liked 302 Times in 86 Posts
If you are starting with a new trans and convertor 7 quarts is a good place to start, you don't want to overfill a 200.
jimmyparker is offline   Reply With Quote
Old 02-04-2018, 09:32 PM   #5
J.R. Haddad
Thanks Jimmy.
Old 02-04-2018, 11:27 PM   #6
MR DERBY CITY
Liked 7,783 Times in 1,495 Posts
Just curious, do you not have a dipstick ?
Old 02-04-2018, 11:56 PM   #7
Kevin Love
Liked 19 Times in 10 Posts
Go to Turbo Action's website-there is a tech bulletin outlining fluid levels for metric 200s
Kevin Love 5666 STK/SS
Kevin Love is offline   Reply With Quote
Old 02-05-2018, 12:23 AM   #8
J.R. Haddad
Yes M.J. I have a dipstick, but it is a Lokar and they are tough to read
the same day you put oil in them. I just wanted some other opinions
to get it close when I fired it up. Tough crowd tonight.
Old 02-05-2018, 12:40 AM   #9
ss3011
ss3011's Avatar
Liked 238 Times in 113 Posts
It's important that you check the calibration of your dipstick . With a stock pan the " Full Hot" line should be at the same level as the pan gasket . Keep in mind that Full Hot means the fluid is at 200 degF . The factory dipstick also has a min line which is at the bottom of the cross hatch marks . The min line is a full mark at 70 degF. You want to make sure the fluid level never exceeds the Full Hot line , because if the Fluid gets up into the rotating parts , it will froth up like a milkshake . This will cause all kinds of problems , the worst being oil out the breather which, if it gets on hot parts , could cause a fire .
Old 02-05-2018, 09:55 AM   #10
Mike Pearson
Mike Pearson's Avatar
Liked 1,903 Times in 571 Posts
If it has an extended pick up on it then you don't need anymore fluid than with the stock pan.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
