Liked 685 Times in 204 Posts
Superstock is full and just a few Stock spots left. Filled at 5 grade points.
Liked 2,354 Times in 554 Posts
Drag Racing, enjoy it while it lasts.....
Liked 205 Times in 93 Posts
can somebody explain this grade point deal please...
Liked 900 Times in 191 Posts
Bob Don 128 SS |
Liked 61 Times in 26 Posts
Liked 3,179 Times in 972 Posts
https://www.nhraeventreg.com/2018relsched.html
http://promod.nhra.com/UserFiles/fil...ING_SYSTEM.pdf https://www.nhraeventreg.com/login.asp?from=/store.asp& First link is the schedule showing how many grade points are needed within a given time up till the Monday PM of the coming weekend's event. Second link is how grade points are earned. Essentially earned in either Divisionals or National Opens. Those can be earned in out of division series but obviously the first opportunity to earn a grade point will be the Orlando Divisional. Third link provides how you get registered to enter. You'll need to have an active competition number for the class you want to start earning grade points in. Your home division office can assist you if you need help for some reason. At Orlando for instance you could just show up with a legal car and get a competition number at the D2 trailer provided it doesn't require a competition license that requires the witness of licensing runs, which typically aren't allowed unless you coordinate with the division so that it can be completed on the T&T preceding the event. Would encourage you to have all of this done prior to the Divisional you're seeking to enter though.
thankyou.
Liked 7,937 Times in 1,518 Posts
Too easy for people to run a divisional and a national back to back, I expected this to fill quick.
Todd Greene |
