Old 12-06-2017, 02:28 PM   #7
Nmbr1GMfan
Default Re: Shock options?
Originally Posted by Hacksaw View Post
I would suggest you stay with the rear Calverts and upgrade the fronts. Look for a double adjustable. You will want it soft on the rebound but very stiff on compression to control bounce from launch and gear changes. Consider Afco, they use a single knob on bottom for compression and you adjust rebound through upper shaft with allen wrench. Remember you must modify lower control arm to suit for clearance and or mounting.
Originally Posted by HandOverFist View Post
What Hacksaw was saying is you will likely need to clearance the holes in the lower control arms...the body of the shocks are a bit fatter than factory units.
Thanks guys for the tip, shocks came in today and yes the lower arms need some tweaking for fitment.
Todd Greene
