I need to install a transmission shield on my 1986 Monte Carlo for next season. I'm curious if anyone could give me some feed back on which manufacturer(s) makes one for a T350 that fits well under the stock floor.
Any help would be greatly appreciated. Regards, Patrick. |
Liked 2 Times in 1 Post
We fit the CSR Super Shields 833 without modification, on the Malibu. Piece of mind, yes, but expensive!
https://www.summitracing.com/int/parts/csi-833/overview/
RT - SS/X circa 1972. ![]() Talbot Racing Family |
Liked 239 Times in 114 Posts
You will spend the most time fitting the CSR shield to the transmission . Most of the extra lugs and bumps need to be removed from the case . Good product though , and you get a flexplate shield too .
Liked 133 Times in 76 Posts
How do you get the CSR shield to clear the vent tube? I've trimmed the case but they didn't leave any room for the vent. I've tried putting one on my 3rd gen Camaro but it's too tight at the bellhousing to floor area.
You might be able to plug the original vent , and relocate it to the extension housing .
Liked 704 Times in 281 Posts
Sorry I don't know the manufacture of mine but it is the5 sided aluminum style with metal straps holding it in place. Plenty of room with 350. Currently have a 400 in car and its a little tight but not a problem. The tunnels to me are decent in size. Just looked on Hughes Transmission website and they have 1 part #HP9750. That's the one I had with 350 trans
Thank you for all of the replies gentlemen!
That's what we did, then put an ATI overflow can on it.
Liked 26 Times in 12 Posts
Liked 215 Times in 86 Posts
Ok guys , blanket or shield and why for 2018 ....
