Old 11-24-2017, 07:29 PM   #4
Nmbr1GMfan
Default Re: Shock options?
Originally Posted by Hacksaw View Post
I would suggest you stay with the rear Calverts and upgrade the fronts. Look for a double adjustable. You will want it soft on the rebound but very stiff on compression to control bounce from launch and gear changes. Consider Afco, they use a single knob on bottom for compression and you adjust rebound through upper shaft with allen wrench. Remember you must modify lower control arm to suit for clearance and or mounting.
Thanks, looks like Afco has some that even have factory mounting options.
Todd Greene
