Old 11-21-2017, 01:25 PM   #1
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Default Re: E shift ?
[QUOTE=Mark Yacavone;550093]What the heck is a "non computer-controlled electronic-fuel-injected vehicle", NHRA?[/QUOTE
pre 92 car with non computer controlled transmission with electronic-fuel-injected vehicle
I think could be wrong
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 11-21-2017, 01:35 PM   #2
HR9121
HR9121's Avatar
[QUOTE=dartman;550118]
I sent Dave Ley a message last night just clarification. He said the rule is the same as before for fuel injected cars but the addition to the rule was to clarify because some of the factory hot rods were using air operated or electric shifters.
James Williamson
W200 J/SA. SS/JA
Old 11-21-2017, 01:47 PM   #3
HR9121
HR9121's Avatar
It really doesn't matter to me either way, I didn't have anything to getting the rule in and I wouldn't through a fit if they did away with it all together but as long as its legal I will use it.
James Williamson
W200 J/SA. SS/JA
Old 11-21-2017, 06:24 PM   #4
Liked 5,147 Times in 1,964 Posts
Okay, so the way I'm hearing this is a 1977 Seville 350 can have electric up-shift, but a 1977 Coupe DeVille 425 can't?
Who thought that rule up?
Never mind. I already know.
Old 11-21-2017, 09:20 PM   #5
Kdw1403
Liked 68 Times in 22 Posts
Thanks guys for all the responses. Good luck next season
Kdw1403 is offline   Reply With Quote
Old 11-21-2017, 10:37 PM   #6
MR DERBY CITY
Liked 8,205 Times in 1,536 Posts
[QUOTE=HR9121;550121]
Correct, some of the millionaires were bending the rules a tad bit....LOL.....
Old 11-22-2017, 01:07 AM   #7
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Here is what the rule revision says.
Electronic rpm controls for the electric
(internal or external to the transmission) shifting of OEM electric shift automatic
transmissions permitted in computer-controlled vehicles only.
They added the words "OEM electric shift" to the previous rule.
The way I read it only OEM electronic transmissions can be electrically controlled. I hope I'm wrong in my interpretation. I also think all cars should be able to use it. Having both hands on the wheel should be safer than having one hand on the wheel, one on the shifter with your attention on the tach to hit shift points.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 11-22-2017, 11:58 AM   #8
Chris1529
Liked 70 Times in 29 Posts
[QUOTE=Darrel Goheen
Having both hands on the wheel should be safer than having one hand on the wheel, one on the shifter with your attention on the tach to hit shift points.[/QUOTE]
I assume you only put a statement like that on here to see how people will react?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 11-22-2017, 12:52 PM   #9
Darrel Goheen
No, never thought about how anyone would react other than the NHRA rule makers. Can you dispute the statement? Until I bought my Camaro in Oct. 2016, 99.9% of the thousands of passes I made down the track in the last 17 years was done with one hand on the wheel, one on the shifter and most of my attention on the tach until my second shift.
Old 11-22-2017, 12:05 PM   #10
[QUOTE=Darrel Goheen;550166]
The way I read it only OEM electronic transmissions can be electrically controlled. .
Yes , that would make sense..but as we all know, in this tech/no tech era...
I already commented on the last part with your premise, so I cut it out.
