Decided to run modified super stock
Can I run dry sump system and is there a restriction on fuel ? Thanks Bob |
Liked 780 Times in 194 Posts
Do you have a rule book?
Just ordered one this morning
Liked 11 Times in 8 Posts
Unless something has changed the MX classes are the only ones you can run a dry sump in. Fuels, there is an accepted list on NHRA's site I believe.
Joe Buchanan SS/BX 3117 |
Liked 312 Times in 175 Posts
Dwight is right. Get a rule book. Dry sump permitted in SS/MX only. Fuel options and restrictions. Plan, plan, and plan some more. Good luck.
Accepted fuel is found here:
http://www.classracerinfo.com/AFuelList.aspx and here: http://promod.nhra.com/userfiles/fil...edProducts.pdf
Liked 1,600 Times in 583 Posts
Either an internal wet-sump oil pump or an external, single-stage oil pump is all that is allowed.
#8 | |
Liked 237 Times in 126 Posts
All those classes follow SS rules with exceptions listed separately in the book. Dry sump is allowed in SS/ES, SS/FS and SS/GS which are 4 cylinder classes. Read the rules line by line and ask questions. Best suggestion is to find a racer running your engine build in your chosen category. That will take a lot of the guesswork out of the process for you.
#9 | |
#10 | |
"OIL PUMP External single-stage oil pump permitted. OIL SYSTEM Dry-sump system allowed in ES, FS, and GS."
