Old 11-05-2017, 01:05 PM   #7
rod
Liked 20 Times in 15 Posts
Default Re: axle bearing leak ?
Funny how the mind forgets and then is caused to bring back info. I do remember using heavy old style bearing grease, [like for front wheel bearings]
I did check the vent [pipe type with a loose cap]. it is OK.
in this small town, I will bet 'O' rings will be next to impossible to find, should I need one.
thanks all for the replys.
Rod in AZ
rod is offline   Reply With Quote
