Old 10-26-2017, 10:35 AM   #1
MIRADA
MIRADA's Avatar
Default Iron heads vs Aluminum small block Chrysler .
I know this question has likely been asked a lot but anyone using the replacement NHRA approved aluminum heads are you seeing gains , or would you have not spent the money in retrospect? Pros and cons would be great to hear , I am looking at getting a set done .. thanks
Alan Harper
SS/KA 1072
Dodge Mirada
MIRADA is offline   Reply With Quote
Old 10-27-2017, 06:05 PM   #2
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
Default Re: Iron heads vs Aluminum small block Chrysler .
I got a set I was going to use on a 360 build, but the intake port volume is too much for a 360. So they are sitting in my garage yet. Didn't want to cut the intake surface for NHRA Stock.
Patric Fox is offline   Reply With Quote
Old 10-27-2017, 06:51 PM   #3
David Lee
Liked 346 Times in 126 Posts
talk to shane at precision cylinder heads
Old 11-07-2017, 12:37 PM   #4
James L Miller
Liked 25 Times in 16 Posts
I think the aluminum heads would be great for SS where you can weld up the ports and reshape them. Not sure about stock unless it was for a big valve 340 with 2.02" intake valves. BB heads are worse with too big of valve sizes for stock. I suppose it depends on your wallet. It would be interesting to hear of the cost difference between prepped iron and aluminum heads.
Mopar 2 Ya!
Old 11-07-2017, 04:42 PM   #5
GTX JOHN
Liked 2,493 Times in 700 Posts
It appears most real fast 340 Stockers have them now.
They require a lot of work to be successful and are not cheap!!
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
