Old 10-22-2017, 02:34 PM   #1
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Default Re: Brakes Fix
Pedal ratio is most impoetant on these aftermarket brakes. I am in the middle of it finding my ratio is 7 to one when I need 6-1. I have approx 800 psi and and going to make pedal correct this week looking for 1000 at rear.
Always listen to the manufacturer of your master cylinder.
It did not click w me intil we spoke at work and realized its like using a pry bar and the leverage needed.
Chris
chris ok is offline   Reply With Quote
Old 10-22-2017, 10:06 PM   #2
Eman
Liked 133 Times in 76 Posts
If your ratio is 7:1 and you reduce it to 6:1 you will have less leverage therefore less multiplied force resulting in lower brake pressure.
Old 10-22-2017, 11:41 PM   #3
chris ok
chris ok's Avatar
Sorry i had it backwards. Thank you for the correction. It is what i meant.
