#11 |
Liked 33 Times in 16 Posts
Rich Taylor I/SA - 321 |
#12 | |
Liked 61 Times in 26 Posts
#13 |
Liked 138 Times in 51 Posts
This problem has been discussed before several times. Holeshot Wheels make a wide variety of one piece and 3 piece wheels. Good balance of weight & strength. My car is 3,560+.
One piece selection: https://holeshotwheels.com/collections/1-pc-wheels I've run Holeshots for many years without such issues, but everything should be checked/replaced periodically. Just recently I've had my second OEM 2007 Pace Trailer aluminum wheel develop a leak through the aluminum. Nothing was visible, but apparently the porous aluminum developed a crack after years of use. The trailer has stayed below it's 12,000 lb rating at around 10,500.
LOCOMOTION Racing |
#14 | |
Liked 13 Times in 6 Posts
#15 |
Liked 269 Times in 99 Posts
FWIW
How the car is tied down in the trailer may be the problem or part of it. If tie downs are parallel the car will not move forward or back but will rock side to side while on the road. Cross or X tie downs front & rear side loading is greatly reduced. Also tie down the car so it will not move up & down this will wear out your shocks in a few trips. May require adding more tie downs.
#16 |
Liked 19 Times in 3 Posts
Bogart makes a back plate version for the spoke wheels.
It comes black and might do the trick. Jim |
