Old 09-29-2017, 09:17 AM   #21
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Default Re: Quadrajet problems
Tighten air flap spring just a hair and see if that helps.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 09-29-2017, 09:36 AM   #22
Jim Kaekel
Liked 535 Times in 110 Posts
Originally Posted by mike pearson View Post
danny did some beautiful work on q jets.
x2!
Jim Kaekel 3836 STK
Old 10-04-2017, 03:06 PM   #23
ChevelleStocker
ChevelleStocker's Avatar
Liked 35 Times in 3 Posts
How much fuel pressure do you guys suggest for a Quadrajet?
I spent a few race weekends this year struggling with the hesitation issue and couldn't find out what was the problem. So now I'm wondering if too high fuel pressure could cause this issue as we raised it a little during last summer.
K/S #570
'74 Chevrolet Malibu Classic
ChevelleStocker is offline   Reply With Quote
Old 10-04-2017, 03:51 PM   #24
Hacksaw
Liked 311 Times in 175 Posts
Iv'e had more than one "carb guy" tell me that 5.5 lbs of fuel pressure is max.
Old 10-04-2017, 04:36 PM   #25
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
I run mine a 6 lbs. low pressure and plenty of volume is what is needed on a Q Jet. one gallon in 30 seconds is about the minimum you can get away with.
Mike Pearson 2485 SS
Old 10-05-2017, 01:02 AM   #26
ChevelleStocker
Thanks guys, so it looks like I'll have to lower the fuel pressure when we can get to the track the next time. Now I was running with 7 lbs pressure, so it's interesting to see if that could fix the bog when launching.
K/S #570
Old 10-11-2017, 10:56 AM   #27
Future Super Stocker
I build quite a few Q-jets. . For the small block I recommend .135 needle and seat. Use a Y-block off the regulator to the carb for a supply of fuel volume and use 5.5 - 7 fuel pressure. 6.5 is more than enough for the Q-jet. Rear flaps may need adjusting, but really done at the track.They should open at 1.350 for most and tension is adjusted 1/8" of a turn tighter or looser. Your Accl. pump shot can also be modified as well. There is mods that can be done to the carb for better performance. WD-40 and Marvels Mystery oil is your best friend. Keep all shafts and linkage lubricated. Hope this helps.
Future Super Stocker is offline   Reply With Quote
Old 10-11-2017, 11:52 AM   #28
Cool Re: Quadrajet problems
Danny Ashley I believe started the slide plate for the secondary rods. But note that the air horn needs to be milled in the area that the slide plate goes
