#11 |
Liked 346 Times in 126 Posts
Mark, I value your opinion. I was also thinking of making a small board and mounting it to the upper flat section of the driver's firewall
#12 |
Liked 133 Times in 76 Posts
Here's a link to some good info and a wire sizing chart http://www.yellowbullet.com/forum/showthread.php?t=431340&highlight=wiring+skills Do yourself a big favor and buy a lot of different color wire and also make a wiring diagram. At home it's no big deal to trace circuits, at the track it's frustrating.
![]() Last edited by Eman; 09-15-2017 at 10:42 AM. |
#13 |
Liked 312 Times in 175 Posts
Putting all those relays together in the glove box or on a piece of aluminium in the driver's compartment sure looks nice and tidy. Guess what happens if your fuel pump self destructs and dead shorts. I'll tell you, your heavy feed wire to the pump will fry all the way back to your fancy relay panel melting every other wire it's close to. How would I know that?
#14 |
Liked 237 Times in 126 Posts
All my circuits are fused no matter what amperage they run. I have a breaker in the main power distribution block, too. It shut my car off when I floored it once. Something big shorted out. Nothing burned. Same for the fuel pump. Shorts pop fuses.
#15 |
Liked 33 Times in 16 Posts
Same here...everything fused and fused correctly. Funny, why would anyone take advice from someone who admitted to burning his junk down?
Rich Taylor I/SA - 321 |
#16 | |
#17 |
My stuff was all fused through an ARC panel. Maybe the pump did not dead short, but the feed wire melted back to the relay and the pump was toast. Never burned it down. Funny, how my junk managed to set the NHRA SS record 3 times.
#18 |
I had an ARC relay set before I rebuilt my panel. One of the relays went bad right away and all of the wires seemed too small a gauge for the amps required by race electronics. A relay is just a low voltage switch in a high current draw line. The wire in from power and out to the device still needs to match the needs of the load. I can see a bad fuel pump burning out 18-22 gauge wire on an ARC relay. My Pico relays came with 14G pigtails.
#19 | |
I have a friend with an ARC panel and it was the same deal but he didn't have a relay and still burned the wire, basically his wire became the fusible link. |
#20 | |
