Old 08-29-2017, 04:06 PM   #26
Default Re: My 88 Olds wagone U/SA 10 Pennies
Mark,
Like I shared with Jeff, be careful with the washers.
Commercial washers, even the high strength ones, are usually Chinesium and will deform.
Talking from actual experience with some lifters I shimmed with high grade hardened washers and they squeezed to a thinner dimension.
Ended buying some 7075-T6 Aluminum round stock and cut it to the proper length.
I will plead guilty of not using much RPM and valve spring pressure on our latest combo.
So, when in doubt, leave it to the engineer.
