Old 08-25-2017, 01:04 PM   #1
Todd Gross
Liked 54 Times in 24 Posts
Default Re: cross breading of engines in Stock and/or Super Stock
I would think so. I have a friend that runs a 64 chevelle with a COPO style LS7 in Super Stock. I am not sure what the designation is.
You could email pat at NHRA and ask him about the combo you wish to run. pcvengros@nhra.com
Todd Gross
3323 FS/E,F
Todd Gross is offline   Reply With Quote
Old 08-25-2017, 01:53 PM   #2
BRETV
Liked 776 Times in 199 Posts
You could run it in Super Stock under the new FGT/? class. You use an older car in the stock guide, like your 66 Mustang with a new/ 2008 or newer engine, like in your case 5.0 Coyote motor that is legal in a new cobra jet. Hope that helps.
Bret Velde
2003 SS/LA
BRETV is offline   Reply With Quote
Old 08-25-2017, 02:44 PM   #3
jmcarter
jmcarter's Avatar
Liked 3,165 Times in 969 Posts
Easy peasy...use Dwight Sutherland's great tool...link here. Select the year/make/model of car and then select one of the weight/power values and it will then let pick "GT Class" and select the engine...you then have the potential classes to pick from.
http://www.classracerinfo.com
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 08-25-2017, 03:07 PM   #4
SwillRacer
Liked 5 Times in 1 Post
Thanks for the help guys!!
One last question: I was looking at the Stock class rules years ago (I was always a foxbody guy) and I saw the success that Evan Smith had with his MM&FF Project Stocker. I recall that rotating assemblies had to come from an approved list as well as ported stock cyl head castings were illegal.
Would this apply in the GT classes?
My cyl heads are heavily ported, oversized valves, custom cams, aftermarket pistons and rods,etc.....
Thanks again!
SwillRacer is offline   Reply With Quote
Old 08-25-2017, 03:44 PM   #5
BRETV
Thanks again!
Nope, the GT classes are Superstock classes, so porting, polishing, any cam and valvetrain, etc. Still gonna need the rule book for the specifics. I'm a foxbody guy too!
Bret Velde
2003 SS/LA
Old 08-25-2017, 04:42 PM   #6
Hacksaw
Liked 308 Times in 173 Posts
Don't think there is any chance your combo will fit into a GT class. You need to meet stock port volumes, stock type configuration pistons and standard valve sizes just to begin with. Maybe a SS modified class, SS/AM or SS/AS ?
Old 08-25-2017, 05:09 PM   #7
Jim Caughlin
Liked 800 Times in 244 Posts
The other issue would be the chassis, I am thinking that you had to do some pretty extensive mods to make a Coyote engine fit in a '66 Mustang chassis. The towers and suspension components have to be dimensionally stock. That would be a no go also.
Jim Caughlin is offline   Reply With Quote
