Liked 7 Times in 5 Posts
That is very interesting i've been trying to imagine how to make the box easily removable and leave the t-brake still working correctly.
#2 | |
Liked 431 Times in 224 Posts
http://drr.infopop.cc/eve/forums/a/t...876#6807081876 For a K+R (or Dedenbear, for that matter), your 'dummy plug' would simply have the wires that went to the 'Button' and 'Transbrake' terminals on the delay box tied together. If button polarity is important to you (it really shouldn't be), make sure you go to the manufacturer's website and download the manual to verify it. Some of the lower numbered Biondo boxes do use +12V to the button. I believe all of the K+R and Dedenbear boxes use +12V, but I'm not 100% sure.
S/ST 51 S/C 53 |
Liked 889 Times in 239 Posts
Can't beat the K&R box for east of use and dependability . I feel the display is much easier to see in daylight , and switching screens to change delay or timer settings is easier than almost any other box.
Especially for those last minuet delay adjustments when the starter decides to spray the bald spots on the starting line when you are in the burnout box.
Thanks for the info Just pulled the trigger on a K&R PCT 1 plus can't wait to try out delay box racing.
Liked 38 Times in 33 Posts
Been using a K & R for the past 5/years. Before that it was a Biondo 450.
Both are top of the line in my book...... |
Liked 4 Times in 3 Posts
whats everyones opinion of dedenbear?
They work just fine, but I feel like they are a little behind the times. I'm not aware of missing features, but screen size and ease of use leave something to be desired compared to Digital Delay and K+R.
If they were priced lower than the others, then they would be a consideration. But they aren't.
S/ST 51 S/C 53 |
