Old 08-08-2017, 12:21 PM   #371
Default Re: Important if you run D-H/S or SA
I'm pretty sure aluminum cuts, welds, and grinds easier too.
I know. That's not worth anything either.
Old 08-08-2017, 12:45 PM   #372
Race Clean
Liked 129 Times in 53 Posts
I haven't posted in years, probably will be years again until next time.
I just couldn't resist this time.
I also think the intake shouldn't been allowed, like everything else thats been going on in the past,but why didn't we start this renegade 10-15 years ago????
I can understand the pain of the Hills who has got their 350 downrated quite a bit only now to get molested by a mopar with a totally bogus intake.(if they use it)
I dont remember if the Fords were the first out but I do remember police Cams,Chevy Rods, Shelbys with single carb,Dual carb,big cam,small cam,high comp,low comp or whatever, 390s with oil pans touching the ground and then if you open the the hood it's "Edelbrock everything" + a Holley I am not sure about.
I remember from back in the day that I was thinking: the Ford Guys must have someone in the committee who really likes them alot.
Not to speak about the 396 aluminum head engine that showed up in the 90's,is there a single oem part on that engine now?
Is there really a lack of intakes and Carbs for the B.B. Chevys? Is the aftermarket intake worth a total of 0.0 and thats why it is on every car?
Still no mention of all above, but this Mopar intake really got people concerned.
This thread to me seem to be about all that injustice that happened in the past but happens to single out this one instance.
Flame Away , I am going into retirement again!
Race Clean is offline   Reply With Quote
Old 08-08-2017, 01:22 PM   #373
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Aluminum rods and titanium valves will be here soon. See there will be a steel shortage so we'll have to go to aluminum and titanium. Oh and there will be no advantage at all using them 😉
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 08-08-2017, 01:29 PM   #374
Greg Hill
Liked 279 Times in 68 Posts
I agree with you about the after market parts. As a friend of mine said about the 390 Fords, they are school bus motors. One thing you are not right about is the "Hills" getting their 350 motor down rated . I only built one of the 70 LT 1's after it was factored in 2002 and I had nothing to do with getting it defactored. No one in their right mind would run one at 360 hp. I always ran the 71-72 combination which was rated at 315 hp and factory rated at 330 or 255 depending on which year you claimed. I have never written a letter trying to get anything defactored.
Greg Hill 4171 STK
Old 08-08-2017, 03:09 PM   #375
BG56
Liked 295 Times in 111 Posts
Originally Posted by Wayne Kerr View Post
I've followed this thread for a little while, and I am not that smart, so help me out here.
Someone lobbied NHRA to allow an aftermarket intake manifold in stock eliminator. Correct?
Yet this manifold has ZERO performance benefit?
See you at the races,
Wayne Kerr
Perhaps mentioned previously, if so I apologize, but maybe it was an "enhancement" to the Manufacturer? (of the part)
Old 08-08-2017, 03:41 PM   #376
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Originally Posted by Greg Hill View Post
If you don't think they turn a bunch more rpm than they did 20 years you must of been sleeping this whole time. It's amazing what tons of spring pressure, roller rockers, and new cam lobe designs will do.
x2
BTW The track where the d/sa record was set is a very very fast track.I was the next car down the track and was -1 plus under.He did everything right including,the combo, the day,the track, the weather and traction was the best I've seen any where.
you should be happy for them.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 08-08-2017, 04:39 PM   #377
junior barns
Liked 20 Times in 14 Posts
This run should receive automatic HP How much is it going to get and when??
junior barns is offline   Reply With Quote
Old 08-08-2017, 04:43 PM   #378
Greg Hill
Originally Posted by dartman View Post
x2
I am happy for them. I congratulated Jerry. It was a hell of a run!
Greg Hill 4171 STK
Old 08-08-2017, 05:57 PM   #379
David Lee
Liked 346 Times in 126 Posts
At a National open, none at all
Old 08-08-2017, 06:24 PM   #380
Question Re: Important if you run D-H/S or SA
Hmmm..no comments yet
Kinda wondering about the LD4B manifold now on the 273 4bbls.
Same basic manifold as the one in question here.
No gain on that one either?
