Liked 705 Times in 282 Posts
I built this car like my old Super Stock Monte aftermarket 4 link with the exception of mini tube and using 12x30 tire. My question is I need to add weight and I know on top of the rear end is a great place, but wanting to know adding weight on frame where 4 link would intersect would be a great place. I'm looking to add 150lb at floor behind drivers seating and my thought was 4 link would work rear tires harder and plant them better knowing it had the weight at the intersection of 4 link. Any thoughts? Thanks in advance. Jeff
#2 | |
Liked 535 Times in 110 Posts
Jim Kaekel 3836 STK |
Thanks Jim. I had someone private message me the same location but try to go higher such as rear roll cage down bars. Now to come up with 150lb and secure as I only have 60lb of lead.
Liked 28 Times in 15 Posts
If you mount a weight box (Moroso - Competition eng) to the hold downs (or a flat steel plate) you can add pieces of steel, wrenches, etc to the box - in addition to the lead.
Liked 239 Times in 114 Posts
Keep weight below the top of the wheelwells (per the rules) Weight ahead of the rear axle will add some static weight to the front end , but could add some dynamic weight during the launch .
Liked 101 Times in 27 Posts
Can the weight box be secured by a thick "sandwich" plate under the car or does it have to be welded to a structural member of the car ????
NHRA AND IHRA STOCK ELIMINATOR 2772 |
Mine is bolted thru the pickup bed - Been thru tech at Nationals and Divisionals for years - don't know if it is in the rule book - 6 bolts on the Moroso box.
#9 | |
Liked 314 Times in 113 Posts
Per Section 11a, page 6 of the 2016 Super Stock Rules: BALLAST. Weight box permitted. Only 100 pounds removable ballast permitted, including box (two-box maximum with 50 pounds each). Must be attached to frame or crossmember with minimum of two 1/2-inch bolts. May not be attached to roll bar or cage. Additional ballast must be permanently attached to frame or crossmember; i.e., bolted with at least two 1/2-inch bolts per 100 pounds, with nut welded to bolt. See WEIGHT. See General Regulations 4:2. I have seen cars and talked with racers who have been through tech at numerous National and Divisional events with weight boxes NOT attached to a frame member. They all told me it was never a problem. So I mounted mine in the corner of the trunk floor with a large plate on the bottom and six bolts holding it in place. Second or third divisional I attended I was told to read the rule book and change it before the next race.
Larry Merk |
#10 | |
